TwinTurbo.NET: Nissan 300ZX forum - Just make sure air flows in one way and not the other (n/m)
twinturbineZ
on June 01, 2008 at 10:25 PM
Re: Just unscrew them..shake them and see if the rattle
posted by Fairladyaffair
on June 01, 2008 at 10:00 PM
Car stutters at 2,000rpms help or should i say HELP!
Fairladyaffair
20:57:57 06/01/08
Any codes? Like code 12?
awesom-o
20:59:57 06/01/08
Re: Any codes? Like code 12?
Fairladyaffair
21:03:12 06/01/08
Is there vacuum on the BOV's...the seafoam will clean
twinturbineZ
21:04:37 06/01/08
Re: Is there vacuum on the BOV's...the seafoam will clean
Fairladyaffair
21:09:08 06/01/08
Should run fine with the seafoam in the tank...If you put it
twinturbineZ
21:16:58 06/01/08
Re: Should run fine with the seafoam in the tank...If you put it
Fairladyaffair
21:30:43 06/01/08
I don't think that's your problem..but it won't
twinturbineZ
21:32:18 06/01/08
Re: I don't think that's your problem..but it won't
Fairladyaffair
21:35:28 06/01/08
Are you saying you feel vacuum from the BOV?
twinturbineZ
21:19:05 06/01/08
Re: Are you saying you feel vacuum from the BOV?
Fairladyaffair
21:29:18 06/01/08
if you feel vacuum from the BOV'S and it's
twinturbineZ
21:33:44 06/01/08
Fairladyaffair
21:33:34 06/01/08
twinturbineZ
21:35:43 06/01/08
Fairladyaffair
22:00:01 06/01/08
Just make sure air flows in one way and not the other (n/m) -
twinturbineZ
22:25:49 06/01/08
New development in problem...
Fairladyaffair
21:55:23 06/01/08
Can you remove them and reinstall the factory
twinturbineZ
22:24:53 06/01/08
